[yt=425,350]JpErm2T1SH0[/yt]
Update Features:
-Added OptiFlasher Picon Loader Full Service (HOT) :
Supported Tested models : DM800hd , DM800se , DM500hd
-Configure & Install/Update Picon
-Install Single Channel Picon Auto (By Server more than 18000 Picons) (Hot)
-Install Single Channel Picon Manual
-Install Picon Device Path with Diffrent Locations:
(/media/usb , /media/hdd , /usr/share/enigma2)
-Auto Configure & Install For Picon_Oled (Tested with DM800se)
-Added SSL-BT Auto Check & Dowload
-Added Custom Baudrate (Manual/Auto: 115200-57600)
-Added Software Auto Check Updates Notification System [Manual/Auto]
-Software Interface Rebuilded
PS: CIFS mode need run OptiFlasher as Admin with
Activated Windows Session Password
For TSFlashbackup use "enigma2-plugin-extensions-tsflashbackup_84b_mipsel" Get if from TSPanel easy !
enigma2-plugin-extensions-tsflashbackup_84.2_mipsel not yet ready & may get message not installed Soon will be added.
For Non-Registered OptiFlasher Key Users Download the SSL-BT Pack Manually & Extract it then
put SSL-BT folder at same path of OptiFlasher
Update Features:
-----------------Link 1
---------------- Link 2
SSL-BT Link ----------------------------------
