Enigma2 OpenSource SH4 Duckbox Project GIT-3447 PKT SVN-1565 NEBULA v1 Image
Image is designed for installation in USB/SATA device
Support receiver: Kathrein UFS910
Kernel stm24-207
Added by sh4 Duckbox Team:
- [lirc] update lirc to 0.9.0 and add patch which increases response time on spark
- fix portmap
- [directfb] fix input driver
- [p191] fix artefacts in minitv picture if watching 1080p tv channels
- [enigma2] fix skinselector bug
- [spark] fix enigma2 keymapping behaviour
- fix aotom vfd subversion error
- [python] force largefile support
- [player] propose fix for missing audio for at least one channel on bard 26 east sat which broadcasts in aac-hen (not tested)
- [spark] improve nand write speed from 5.8mb/s to 6.8mb/s by decreasing partition size, 64mb is enouth. also add padding to flash image generation to eliminate jffs2 filesystem errors due to invalid areas in partition
- [p191] fix aspect of 352x288 channels
- [add] enable rtmpdump ffmpeg
- [FORTIS_HDBOX] fix driver/frontend/stv090x
- [add] libpng-1.5.6
- [busybox] - update to 1.19.4
- [aotom] - small syntax fixes
- deactivate manifester fix only for 576i
- [libeplayer3] fix externel subs segfault
- [boost] - Update to v1.49.0
Added by PKT:
[ALL] add PKT Hdd Manager v1.1
- automount support
- manual mounting 10 defined points to /media
[ALL] add PKT Backup Manager v1.5
- change backup to /hdd/backup location
- quick backup of e2, settings, emu, network, crossepg
- full backup of whole image
[ALL] add PKT SMB Server Manager v1.2
[ALL] add PKT VPN Client Manager v0.7
[ALL] add PKT DLNA Manager v1.1
[ALL] add PKT Auto DeepStandby
[ALL] add PKT FrontPanel Setup 1.2
- fan speed control for ipbox 9900 and ufs922
- VFD brightness
- LED ON/OFF
- VFD utilities
[ALL] add NetworkBrowser for CIFS/NFS management
[ALL] add net patch in /media for CIFS/NFS manager
[ALL] Network changes:
- code optimalization
- fix more bugs
- fix wifi network start
- reorganization WiFi Menu,
- add all WiFi adapter setup to one place
- add support for rt5370 wifi drivers
- fix network setup at first start
[ALL] BP -> Settings : added Video settings ( brightness, saturation, tint )
[ALL] reorganization BluePanel for Mount Center Menu
[ALL] reorganization Multimedia Menu
[ALL] fix HelpMenu
[ALL] add missing WebBouquetEditor
[ALL] swap size 128 -> 64
[ALL] EPG data preserve, to restore after system crash like GS or hard reset.
[ALL] progress fix
[ALL] remove VidBrowser
[ALL] change hard reset code to OK->0->0->0->0 sequence
[ALL] for reboot after 4x"0" added info on VFD - to be sure it was user call
[ALL] remove Moderate Standby
[ALL] added DD Subtitle Player support to new version of KeyMapper
[ALL] fix BitrateViewer
[ALL] DD SubtitlePlayer updated to v.3.09
[ALL] VFD in standby fix for days names
[ALL] HDD Temperature fix - process starts only if activated in SkinSetup
[ALL] add WebMedia 5.0
[ALL] GraphMultiEPG - close plugin after zap channel ( key OK )
[ALL] fast AspectRatio switch - added OSD info
[ALL] some fixes for DVDPlayer -now DVDPlayer should work on SD and HD skins
[ALL] fix MyTube
[ALL] add CEControl plugin - only on STI7111 STI7105 STB
[ALL] fix FTDI & PL2303 status display
[ALL] remove Media Center from BP - available only from download
[ALL] fix EXIT in keymap
[ALL] fix Timeshift - 4:3 channels : restore aspect ratio after TS activation from the letterbox format
[ALL] add 1080p50 mode should work on STI7105, STI7111, STI7110 especially: SF1028, UFS912, HS7810A, HS7110
[ALL] BP added to main menu
[ALL] update PKT FEED - group in categories
[IP9900] VFD REC, HD, Dolby icons fix
[IP9900] fix TXT
[IP9900] clear VFD incons on startup
[IP9000] Pg Up/Dn in EPG
[IP9000] keymap for show Favourites
[IP900] fan absence GS fix
[IP99] autodetect available nims for mgcamd patch
[UFS910] fix memory check
[UFS922] fix cooler speed setup
[SF10X8] fix evremote speed and active long keypress in SF1008SE+
[SF10X8] added SleepTimer for SLEEP key
[SF10X8] keymap fix Channel Up/Down
[SF10X8] fix VFD Icons
[SF1028] fix audio drops
[SF1028] fix multituner in flash version
Known issue:
- on some channels TimeShift turns off after few seconds if time of shift < 7 sec.
- if DVD player make restart GUI, run first any movie in Media Player during 5 sec and next use DVD Player
- [UFS910] instalation on some hardisk make trouble it is probably u-boot bug
THX for Germany translate by daTa deVil
THX for Russian translate by spartak73
FTP login: root, passwd: pkteam
DOWNLOAD:
