Quality of Blu Ray videos are at highest level but that comes with a high price of a large files. If we want to maintain high quality and have everything but with significantly less size we can convert those files into some other formats. One of the best software solutions for conversion is Blu-ray Converter Ultimate that promises great speed and reliability.
Blu-ray Converter Ultimate is available for a download from digzip for free.
After you start this application you will be able to choose the file that you want to convert. Most important formats are supported and you will be able to convert your files into DVD, MKV, AVI, Xbox, PS3 and iPhone/iPad formats.
After everything is set the way you need you will need only to click on convert and conversion will start. Everything is done pretty fast and you will be getting video with no or minimal quality loses depending which format and output file size you have set.
Another great addition to this program is that you will be able to burn your video files to DVD or CD. Also you can transfer them to your mobile device, even there is a large number of similar programs we recommend this one that certainly is one of the best on the market.
Key features of Blu-ray Converter Ultimate:
- Easy to use software complete with straightforward file, audio and subtitles selection, quality optimizer and burning to DVD.
- A menu and chapters are created and the result can be burnt and split over 2 DVDs(depending on output format chosen)
- A wizard-style interface guides the user for a conversion in as little as 2 clicks
Download:
