Nova imagem hyperion v2
Amiko 8900
Added by PKT:
[ALL] OpenPLI updated 10-05-2013
[ALL] python2.7 updated
[ARM] fix firmware update from BP
[ARM] fix subtitles
[ALL] add PKT HDMI-CEC Manager [BP->Settings->HDMI Setup]
[ALL] fix making & cleaning devs for pl2303 & ftdi
[ALL] speedup network test
[ARM] enable automount support
[ARM] add missing libs for mytube
[ALL] add HDD Manager to BP-> Disk Menu
[ALL] Partition Manager to BP-> Disk Menu
[ALL] optimize SWAP script
[ALL] fix SWAP start on box with NAND Image
[ALL] update main menu
[ALL] add DLNA client support menu
[ARM] Add missing rtmpdump for WebMedia 10 and other
[ALL] default PIG on exclude ADB
{ALL} IPTV GS fix for ChannelList
[ALL] skip network check in first assistant
[ipbox] add loading RF modulator in rcS if exists
[ADB] fix autorestore
{ALL} removed unsupported Nonlinear format from AspectRatio
[ALL] fix EPG multifunctioning
[ALL] fix Channel Control plugin support
{7162} fix V.Format key for aspect ratio selection
{ALL} fix python 2.7 plugins import from PKTs server
[ALL] fix map ca0 to ca1
{ALL} standby on/off switching speedup & other internal code changes
{ALL} force reboot function deactivated cause doesn't work so far
[SF918,SF1028] Enable extinguish
[ALL] set default OFF hdmicec function: tv_standby, tv_wakeup, active_menu, active_source
[ALL] fix OpenWebif streaming
[GM7162] add switch between DVB-T/C @BP->Settings->Extra Setup
[ALL] according to @data devil - added additional key info in locations: EPGSelectActions ChannelSelectEPGActions
{ALL} added TELETEXT support in KeyMapper : available for red & yellow color keys
[ARM] Add CrossEPG
[arm] add missing libs
{ARM} fix graphEPG fonts for other skins
[ALL] update channel list
[ALL] update djcrash downloader v1.3.0
- add checking server response
- add update local date field after installation
[ALL] update PKT Samba Server Manager v1.5
- add support for Hypercube
- add some new entry to smb.conf
[ALL] update Media player
-set /hdd as default browsing dir
-set config.mediaplayer.defaultDir=/media/
-functionality fixes
- added dynamic OC
[ALL] update EmuManager v1.1.7
-add properly support of wicardd
{ALL} update BluePanel
- speed up
- optimized code
- small fixes
- num & color keys small functionality fix
- exit key fix
- added boxtype exclude
[ALL] add Overclocking Tool v2.0.8
- add management over/down clocking
- add checking oc driver
- add error message when oc driver is not available
- add downclocking CPU in standby support
- enable Fast Boot support
- add lock/unlock button
- add WARNING message
- add Dynamic OC
- add frequency self calculating algorithm to increase available range of values
- add CPU dynamic frequency control in standby mode when recording
{ALL} InfoCenter
-added CPU frequency read online.
-added Net IP
[ALL] update PKT Install Manager v2.7.7
- add support MultiBoot for GM 990/GM TRIPLEX STB
- fixed exit from Disk Manager
- fix switch between multiboot<->nand_e2
- fix switch between multiboot<->nand_spark
- add Mario Bros cleaning tool
- add additional boot_system check
- set default bootdelay at 10s for gm990
- add reboot button
- add show mounted partition
- add support ext4 file system
- increase choice of size partition from 10GB to 1TB
- add size of left free space
- add excluded extended partition id
- speed up loading install manager & all code in python
- add info when disk or image file is not detected
- add lock installation when disk or image file is not detected
- fix usb and usbhub loading when more than 1 storage device are connected to the STB
- add multiboot for Hypercube
Conditions:
- FAT partition is using for kernels area
- sdx2, sdx3, etc... is using for rootfs
- correctly usb drive partitions can be prepare by Disk manager
- fix refresh status on hypercube
- fix rescan devices after repartition in Disk Manager
- fix detect image to install [hypercube]
- add alternative startup from flash when usb storage can not be initialize [hypercube]
- code optimization
[ALL] Update Backup Manager v2.2
- add full backup of flash for GM990 / TRIPLEX/ Hypercube
- fix checking free space in /hdd
- set copy settings default off
- add copy of channel list revision
- add selection usb or flash image in whole image backup
Known Issues:
[ADB] PIG can cause unexpected uboot remove due to error decoder design - as written by Jacek
We are working around this problem and some changes in this direction have been made, however we can not guarantee 100% secure
[TRIPLEX] for oscam use boxtype=ipbox
[ALL] we not recommended make backup of e2 settings when using Backup Manager from older version!
Special THX to TDT group, all sh4 community and all betatesters.
FTP login: root, passwd: pkteam
Regards
Pozdrawiamy Polish Koders Team
[youtube]http://www.youtube.com/watch?v=PE37arlcj2A[/youtube]
Amiko 8900
:right:Added by PKT:
[ARM] fix subtitles
[ARM] Add CrossEPG
- added dynamic OC
- speed up
- optimized code
- small fixes
- exit key fix
- add Dynamic OC
{ALL} InfoCenter
-added Net IP
- add reboot button
Conditions:
- code optimization
Known Issues:
Regards
